Resonator Question. Removal or replacement?
Old Jun 13, 2009 | 12:08 PM
rogue13_13's Avatar
rogue13_13
Default Resonator Question. Removal or replacement?
Hello, this regards a 2000 Integra GSR.
Recently my exhaust tubing rusted/broke cleanly from the very rear of my resonator after hitting a large bump on the interstate.
The break is so close to the resonator's wider/swelled circumference that traditional methods wont work to join the pipes. I was considering sliding on one of those "expanded" exhaust joints then welding the "expanded" end to the resonator and clamping/welding the other end to the broken pipe... but I am not yet sure that a welder won't simply burn holes in this old metal. Besides, this is plan B (would have to find a welder first).
PLAN A: I want to remove the resonator. It seems much easier and more likely to work. I know everyone on here says that Tegs sound like crap when the resonator is removed, but is that still true even for OEM exhaust systems? And if a straight pipe really would sound like crap, is there a cheap replacement for a resonator... such as putting one of those cheap low restriction "cherry bomb" mufflers between the OEM cat and muffler?
Just curious... I want to do it right, and want it to sound nice... but really don't want to spend hundreds of dollars for the pipe when the problem is a simple break.
Old Jun 13, 2009 | 02:09 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
An OEM equivalent resonator shouldn't break the bank and it is by far the best solution. Google "Walker OEM exhaust" and search their catalog for the part number.
A cherry bomb muffler uses spun fiberglass over a resonated inner tube. They don't do a good job of sound deadening to start and they won't last nearly as long an OEM equivalent resonator. Even if you go to the trouble of making a cherry bomb fit, you will be back to square one in a year or two once the fiberglass packing has sooted up or blown out.
Unless the car is weeks away from being sold or scrapped, I would buy a OEM resonator over the counter. To mount it, trim the ends of the OEM exhaust tubing and use slip-fit connectors and U-clamps to attach the new resonator. That way, you shouldn't have to bother with any welding.
Old Jul 11, 2009 | 07:57 PM
joe_kewl81's Avatar
joe_kewl81
i just ripped my resonator off. It broke around the factory welds so i said screw it and just put a piece of pipe in. The muffler managed to blow out shortly after (was in need of replacing) so i just got a 30 dollar thrush turbo from the parts store and installed it myself. i didnt have a welder so i used fiberglass exhaust wrap and some clamps. The car sounded great. Quiet at low speeds and powerful sound at high rpm.
Old Jul 12, 2009 | 02:23 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
For the love of god do not use a Thrust Turbo, Cherry Bomb, or any other type of $30 AutoZone muffler. I went through 3 of them, in less than 4 months. I now have a magnaflow on the car.
As for the resonator, I would have an exhaust shop cut the resonator away from the rest of the exhaust and weld up another one. Or you could see this as being time to get a new exhaust.
