Windshield Washer Fluid not coming out
Old Jan 28, 2003 | 05:31 AM
BonzoAPD's Avatar
BonzoAPD
Default Windshield Washer Fluid not coming out
What can be the problem? The fluid is not frozen, I checked it. It is also suppose to be good for up to -20degrees
Old Jan 28, 2003 | 05:36 AM
jeff's Avatar
jeff
the nozzle could be clogged. take a safety pin and try cleaning the nozzle.
Old Jan 28, 2003 | 05:55 AM
pringle's Avatar
pringle
Do you hear the windshield water motor?
- If not then check the fuse on it / replace the motor.
Is there a leak in the plumbing?
- Check the plastic pipe under the hood.
Old Jan 28, 2003 | 09:11 AM
tooslow2race's Avatar
tooslow2race
Master Bator
don't feel bad, i don't even have the washer fluid resevoir anymore.
Old Jan 28, 2003 | 03:06 PM
airon's Avatar
airon
AARONNOJIMA.COM
yeah you should check to hear the motor
and see if the lines have fluid in them
Old Jan 28, 2003 | 04:25 PM
Deagle's Avatar
Deagle
Nüb
How do you know it's not frozen? -20C freezes easily in the winter. If you hear the motor running, and a ticking or clicking sound, it's probably frozen in the lines only. Take it through a car wash. It will start running again. Put washer de-icer in and -45C stuff etc...
Old Jan 28, 2003 | 05:59 PM
newgsrdriver's Avatar
newgsrdriver
Check to see if its frozen and also check for leaks in the lines...pop the hood and have someone spray while you watch, or look for little puddles.
Old Jan 29, 2003 | 10:41 AM
BonzoAPD's Avatar
BonzoAPD
this morning the temperature went above freezing and it worked. I think it was frozen in the lines. The motor was working so it had to be the lines freezing over
Old Jan 29, 2003 | 12:37 PM
pringle's Avatar
pringle
Don't put straight water into the windshield washer reservoir.
