tps sensor
Old May 18, 2009 | 05:01 PM
Eddog85's Avatar
Eddog85
Default tps sensor
hello I did engine swap on my 98 integra. I put in used B18b with low miles. I broke my tps sensor when I was putting in my engine now there telling me I need to buy a whole new throttle body. my question is would I mess up my car if I drive without out it and what are the effects of driving with out one.
Old May 18, 2009 | 06:25 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
I don't think the car is going to even run without a TPS sensor.
You have drill out the rivets and put a new on on. It's not a problem.
Old May 18, 2009 | 06:41 PM
Eddog85's Avatar
Eddog85
the car runs the only think is that the gears go in ruff its an automatic. I don't if that's the tps sensor. I took it to the shop to see if they can drill it out and they said they can't that I need a new throttle body. dose the tps have anything to do with the tranny
Old May 18, 2009 | 06:49 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Wait.. The TPS sensor unscrews. You're talking about the MAP sensor. In that case, you do need a new TB.
It's the sensor on the top of the TB right?
Old May 18, 2009 | 06:53 PM
Eddog85's Avatar
Eddog85
its on the back side toward the firewall. it dosent have screw.
Old May 18, 2009 | 07:20 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Can you take a picture?
Old May 19, 2009 | 01:21 PM
Eddog85's Avatar
Eddog85
it dosent let me download it but its the tps sensor
Old May 19, 2009 | 06:58 PM
Eddog85's Avatar
Eddog85
can anyone tell me what that sensor dose
Old May 19, 2009 | 09:27 PM
Spec R's Avatar
Spec R
tps = throttle position sensor
it does what its name inmplies. it tells the ECU how much throttle input you're giving it.
DB Squad
Integra Forum Moderator
Old May 20, 2009 | 02:37 PM
Eddog85's Avatar
Eddog85
cool..what happens if I drive with it unpluged. and do I need a new TB or can I take it to a shop to replace the sensor.
