maintenance light is commin on
Old Jan 11, 2003 | 10:30 PM
shockwave's Avatar
shockwave
Default maintenance light is commin on
hey guys my maintenance light is flashing when i start my integ now... i have had a bad clutch for a month now and i KNOW it has to be replaced asap, do u think its from that? or u think its something like timing belt ect... no weird noises from engine compartment.... it has 140k miles on it and mostly freeway miles... any ideas would help, i know its kinda vague but hey worth a shot
Old Jan 11, 2003 | 11:02 PM
kissmy RS's Avatar
kissmy RS
depending on your year integra there are 2 ways to get rid of the light....or maybe 3
1 if you have a 96 integra there is a key slot on the left side of your steering wheel to the bottom all you have to do is insert the key and it will reset
2. if you have an older integra there is a bluish green button located to the right of the steering wheel and under near the pedals you will have to look almost up at it lying down near the pedals to see it hold the button down for a few secs and it will clear
3 any newer then 96 or older then gen 3 integras i would consult the owners manual or if you dont have it call an acura dealership and ask them where the reset is located
the maint req light is set off according to mileage to the last time it was reset depending on the mileage it will blink or stay on for ignition or in your case (over 7500 miles) stay on...
Old Jan 11, 2003 | 11:12 PM
b00gers's Avatar
b00gers
on my 99 teg...and all G3s....ive always seen that square light underneath the dash.
stick in key
press and hold button
turn key to on or start car
depress button.
Old Jan 12, 2003 | 09:32 AM
shockwave's Avatar
shockwave
mine is a 94 LS
Old Jan 12, 2003 | 10:33 AM
b00gers's Avatar
b00gers
check for the button. stick your head under the steering wheel, and look up. it should be a square button.
Old Jan 12, 2003 | 10:43 AM
Mintegra97's Avatar
Mintegra97
It doesnt mean anything is wrong with you car, it just goes off every 5k miles or something so you will take it to acura.
Old Jan 12, 2003 | 08:17 PM
diskostew's Avatar
diskostew
DiskoStew don't advertise
:rockon: Will, Thanx for posting that... Mine has been on for like a year or so. I just learned how to ignor it, but now I am going to go turn it of.
Old Jan 12, 2003 | 09:06 PM
b00gers's Avatar
b00gers
no problem, i thought the whole world knew of the button already.
Old Jan 15, 2003 | 04:29 AM
integra_blurred's Avatar
integra_blurred
Objects in mirror are loo
Yea, the maintence required thing is just to like let u know oil needs to be changed or whatever, nothing to worry about. You really don't even have to lie down in the floor of your car. If you are sitting in the drivers seat, reach down with your right hand and feel up under the kick panel, it's right there, a little blue square button, easiest thing in the world to do, I kicked myself when i found out too...lol
