Higher compression/Tune?
Old Feb 23, 2009 | 02:21 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Default Higher compression/Tune?
Ok, so I want to put my B18B1 block in my car for this race season to get any gains I can. I have rebuilt the bottom end with the P73 pistons. With the higher compression would I need to get it tuned or would I be safe running it for 8 months or so?
Right now everything is stock head and block. I just wanted to swap the blocks out for the higher compression ratio.
Old Feb 23, 2009 | 07:50 PM
Lynxs1981's Avatar
Lynxs1981
With the smaller change, you will be ok. You won't really need a tune unless you swap for some higher flowing cams.
Old Feb 23, 2009 | 08:21 PM
Spec R's Avatar
Spec R
so you're basically running a stock B18B with a little higher compression? just dont run 87 octane thats all.
DB Squad
Integra Forum Moderator
Old Feb 23, 2009 | 09:47 PM
thetunersource's Avatar
thetunersource
I've seen many a guy that run 11.5 : 1 on 91 pump gas without any problems. What really matters is the dynamic compression required on the engine specs.
Old Feb 24, 2009 | 02:44 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Yeah, I'm just upping the compression. Thanks for the info guys.
Old Feb 24, 2009 | 09:46 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
It all depends on the tune, and timing.
Old Feb 25, 2009 | 07:19 AM
Lynxs1981's Avatar
Lynxs1981
Yea, with just changing the compression a little, the onlyt thing that you might have to change is the timing or maybe use mid grade gas. You wouldn't have to get a tune unless you start changing cams and such.
Old Mar 4, 2009 | 09:39 PM
thetunersource
Why more compression? If you want to get more power just go for more cam.
Old Mar 5, 2009 | 04:02 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Well I was taking A lower engine machining class. I needed some pistons, Rods, And a crank. Cams would be with the head work, Going to take an upper engines class next fall. I wanted to know if I could race on it this season or if I would have to wait till next year and do the full lsvtec setup. Don't have the money now to do any tuning.
Old May 1, 2009 | 07:50 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Well I just got my car all up and running today. Ran into a couple problems along the way. First thing I ran into was when I tried to put the head on my new block. As I was torquing down my last head bolt, It pulled the threads out. After repairing that and installing the engine, I went to start it up. Come to find that the PCV system was changed from 95 to 96. I had plugged the hole in the back of the block and started the engine. Oil shot out all over the back side of my engine bay. So I installed the breather box and started it again. It wasn't running right. I took it to the school and had them run through it and try to find out what was wrong. They couldn't find anything. Turns out I was off by just one tooth on the cam timing. Fixed it and now I'm breaking it in. First race in it is on the 9th.
Old 1/4 mile avg. 15.9
fastest w/tail wind 15.7
We'll see what it runs when I get to the track.
