quickest way to twist
Old Feb 15, 2009 | 10:30 AM
2ltrEGhatch's Avatar
2ltrEGhatch
Default quickest way to twist
need help twisting in the piston on a caliper, whats the quickest way
Old Feb 15, 2009 | 10:42 AM
gsreg94's Avatar
gsreg94
by the $4 tool at pepboys or what ever place is nearest to u
Old Feb 15, 2009 | 12:14 PM
Spec R's Avatar
Spec R
and an extension.
DB Squad
Integra Forum Moderator
Old Feb 15, 2009 | 07:21 PM
cruzalekz's Avatar
cruzalekz
turn it to the piston to the right.
you could also use a long nose plier if you dont have time to buy the square tool but just to warn you, it will be hard but ive done it so many times at the shop so i mean its duable
Old Feb 15, 2009 | 09:30 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
I use one large needle-nose pliers and a channel-lock wrench for leverage.
Spread the pliers apart, get each half of the jaws seated at the ends of the slot on the piston.
Then, clamp down on the hinge of the pliers with the channel-lock wrench to form a lever arm.
