flame outa back when i shift
Old Feb 9, 2009 | 07:42 PM
brandanintegra's Avatar
brandanintegra
Default flame outa back when i shift
ok i have a lsvtec an my 91 teg it runs sweet an it is chiped well when i shift at 8000 rpms flame come outa the exsost pipe now i know the o2 is bad cood this be because of this an im runing 91 octane
Old Feb 9, 2009 | 07:52 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
You want to try again?
Preferably in english, please.
Old Feb 9, 2009 | 08:40 PM
Spec R's Avatar
Spec R
"Okay, I have an LS-VTEC in my 91 Integra. Its chipped and runs sweet. When I shift at 8000rpm, flames come out of the exhaust. Now I know the 02 sensor is bad, could this be because of that? By the way, I'm running 91 octane."
It cant be running that sweet if the O2 sensor is bad.
Replace the sensor if you know its bad. Will it cure the flames? Maybe, maybe not.
DB Squad
Integra Forum Moderator
Old Feb 10, 2009 | 12:39 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Depending on how/what that ECU was chipped for, the 02 could have been deleted from the system. Mine is and I'm tuned with eCtune.
Old Feb 10, 2009 | 02:45 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Also, what was the ECU chipped with? What you could do is take your ECU, cut the jumper pin, and if it stopped, you know it's the tune or base-map on the chip.
Were you actually tuned via dyno or a street tune? Or did you just buy a "chipped" ECU and throw it in your car? I remember when mine was just chipped and I smoothed out the fuel curves I used to pop from the exhaust at idle because I was a little bit lean.
Old Feb 10, 2009 | 03:05 AM
Spec R's Avatar
Spec R
waiting for brandan's answers to these questions.
DB Squad
Old Feb 10, 2009 | 08:31 PM
cruzalekz's Avatar
cruzalekz
running way too rich.
Old Feb 12, 2009 | 11:44 AM
thetunersource's Avatar
thetunersource
Sounds like you are running rich with no cat in your car! Congrats for the awesome flame throwing exhibition! AHHA. Becareful as this is a total cop magnet.
Old Feb 12, 2009 | 02:04 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Sounds like the bad sensor is causing the computer to run it a little richer. Replace the sensor and get back to us.
Old Feb 12, 2009 | 07:50 PM
cruzalekz's Avatar
cruzalekz
the only way is to go to the data stream of your pcm, then look at the data specifically @ the long term fuel trim.
