93 integra won't start
Old Jan 15, 2009 | 05:39 PM
muellteam's Avatar
muellteam
Default 93 integra won't start
All of a sudden my 93 integra won't start, cranks like a big dog but no spark or fuel. I have replaced the fuel pump and fuel filter, main relay, and distributor. I have checked all fuses, now at a loss to try next. Any help appreciated.
Mark
Old Jan 15, 2009 | 08:31 PM
cruzalekz's Avatar
cruzalekz
wow, you already change the main things huh.
so i guess that leaves you with the pcm
maybe it got wet or the ground was lost.
i cant tell you exactly how to check coz i got no wiring diagram in front of me but im pretty sure it has to do with the pcm.
Old Jan 15, 2009 | 09:14 PM
brandanintegra's Avatar
brandanintegra
check ur timeing ,an was the motor runing before ,duble check ur fuel pump an is there power to the fuel pump ,what motor, is it a swap if so what swap
Old Jan 17, 2009 | 02:24 PM
cruzalekz's Avatar
cruzalekz
so what happened? did your timing belt broke?
Old Jan 17, 2009 | 02:29 PM
KrazyAboutHondas's Avatar
KrazyAboutHondas
all motor or nothing
double check the fuse block under the hood, your ecu fuse may be bad. And if that's the problem see what caused it to pop. Had the same problem on my DA
