VTEC Question
Old Jan 2, 2003 | 10:27 PM
drmeatrx's Avatar
drmeatrx
Default VTEC Question
I was wondering if anyone could tell me when the VTEC kicked in on the 94 GS-R. What exactly does it do, I mean I know it electronically controls the valves to be timed in more efficiently, but is that it? Thanks.
Old Jan 2, 2003 | 10:37 PM
crash's Avatar
crash
4400-High lift cam lobe and long intake runners.
5800-High lift cam lobe and short intake runners.
if the conditions are right the ecu activates it by opening a valve that allows oil to flow into the middle rocker arm.when the oil fills it,it pushes pins into the smaller outside rocker arms to make them stay together,so that they can run of the cams middle lobe which is bigger.
Old Jan 2, 2003 | 10:56 PM
Snoopy's Avatar
Snoopy
been there done that
first, use the search button. this topic has been covered many times before.
also, heres an explanation of how vtec works: http://www.howstuffworks.com/question229.htm
