what should i do when....
Old Dec 27, 2002 | 10:57 PM
crash's Avatar
crash
Default what should i do when....
i'm gunna get my timing belt and water pump replaced(cam seal too),and was wondering if theres anything else you guys think i should do at the same time.aslo does $250 for labor only sound right for a timing belt and water pump change on a b18c1?
Old Dec 28, 2002 | 06:14 AM
NSXTC's Avatar
NSXTC
2009 Nissan GTR
My shop does all B series and D series timing belts for $350.00 total, so i'd have to say that sounds about right. The water pump should only bump the total cost around $100.00 or so. Once you break it down enough to change the timing belt, the water pump is only a few more bolts, so they really should charge you minimum for labor. I think dealer cost is somewhere around $75-90 for a water pump. What you've listed is exactly what you need to change. Can't hurt to slap some new drive belts on there as well, while youre into it. Good luck.
Old Dec 28, 2002 | 06:35 AM
1qckG2teg's Avatar
1qckG2teg
i just finished doing a timing belt and water pump the other day and i suggest that you get new cam seals and crank seal as well.....your in there and you might as well get them done
later
