Annoying Rattling 3000-3400RPM 96 GSR
Old Dec 7, 2008 | 11:03 PM
integraclownnu's Avatar
integraclownnu
Default Annoying Rattling 3000-3400RPM 96 GSR
Bought a 96 GSR back in March as the 2nd owner. Everything is bone stock on this car, down to the radio. The car has been making a rattling noise around 3000-3400RPM range. Running on the highway for two hours mitigates the sound a little. I've taken some of the exhaust shielding off around the cat, but the noise is still there. This leads me to believe this is the shielding around the exhaust manifold. This is really annoying, especially driving in town. Do I just need to buy an aftermarket header? Does anyone have this problem?
Old Dec 8, 2008 | 12:23 AM
Spec R's Avatar
Spec R
its nothing a muffler shop cant diagnose. 40 bucks out of your pocket usually to have them diagnose/repair the problem.
u could do it yourself if you're confident with your jackstands and know how to weld.
DB Squad
Integra Forum Moderator
Old Dec 8, 2008 | 12:35 PM
Lynxs1981's Avatar
Lynxs1981
Can't confirm, but I have been told before that these engines have a rattle around that rpm range that can be coming from the engine bearings. How many miles?
Old Dec 8, 2008 | 06:22 PM
integraclownnu
She's got 213k on her, but I doubt it's the bearings. Any bearing that would make that noise would have gone out a long time ago. It's a very loud rattle. Also, my engine would literally explode if it was a bearing when I hit redline.
I don't really have any money (going to college) so I might try taking the heat shield off of the exhaust manifold. When I get money again, I should just buy an aftermarket header.
Old Dec 8, 2008 | 08:28 PM
Spec R's Avatar
Spec R
i doubt its that heatshield. its likely the one above the cat, or the ones near it.
DB Squad
Old Dec 8, 2008 | 08:51 PM
Schwa's Avatar
Schwa
Schiggity
Probably the one around the cat. The metal is quite thin where the two halves bolt together, so it could just corrode away and be left hanging and allowed to rattle.
For mine, I just used a hose clamp to clamp the heatshield right up against the cat and prevent any vibrations.
You can also just rip it right out if the other bolts are easy to remove.
Old Dec 9, 2008 | 08:40 AM
Lynxs1981's Avatar
Lynxs1981
Also check the springs holding the cat and pipe together.
Old Dec 12, 2008 | 08:02 PM
Snoopy's Avatar
Snoopy
been there done that
sounds like you have the infamous downpipe rattle gsr's are known for. basically, the downpipe is double walled and the weld's on the inner wall break allowing it to rattle against the outer.
you can try to find another downpipe or just replace the entire thing with an aftermarket header.
Old Dec 14, 2008 | 12:44 PM
integraclownnu
I did remove the shielding around the cat so that's not it. I think I will tolerate it for now until I find a header. Thank you everyone who posted.
