Gutted Cat
Old Dec 23, 2002 | 07:46 PM
el diablo's Avatar
el diablo
Jeeebus......Help Me!!!!!
Default Gutted Cat
From the sound I can pretty much figure out what it is but how do you go about doing it and why? I assume you would no longer meet smog regulations. Is this also correct???
Thanks
Old Dec 23, 2002 | 07:55 PM
dubcac's Avatar
dubcac
I
Why would you wanna do it? You'll just end up sounding like a jackass. The car will be VERY buzzy, you won't pass smog, and your cat will be hosed. Just go buy a high flow cat. Same results, still sounds normal. And to be honest, with only bolt ons you won't gain much, if anything at all.
Old Dec 23, 2002 | 09:53 PM
97teg's Avatar
97teg
you may actually loose power because of the turbulence caused by gutting the cat.
Old Dec 24, 2002 | 12:25 AM
el diablo's Avatar
el diablo
Im not interested in doing it I just wanted to know the hows and whys to doing it.
Old Dec 24, 2002 | 05:46 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Why would someone do it? To remove a bottleneck in the exhaust system. As to how I have no clue.
Shingo
Old Dec 24, 2002 | 07:20 AM
pomansouth's Avatar
pomansouth
well from what i know my friend used a screw driver after he got his cat off and just started poking **** out of it. he's domestic so it made his truch sound better
Old Dec 24, 2002 | 12:51 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The stock cat doesn't pose much of a restriction. If your cat is old and has a lot of miles on it though, all the trapped smog particles do eventually slow things down. It's like a sponge, it can only suck up so much before it fills up.
As long as your car is over 5 years or 50,000 miles you can legally replace the cat with a "high flow" unit from companies like Carsound, Landspeed Racing or Random Technology.
Old Dec 24, 2002 | 01:34 PM
crash's Avatar
crash
woh where did you get that 5 year/50k mile rule?is that for california too?
Old Dec 24, 2002 | 01:43 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Dunno about California. I do know that if you're past 5 yr/50,000 miles in most places you can replace the cat for an aftermarket one.
For Cali, if the heat shields are still in place there's no way to tell from a visual inspection that anything is different. So if it still passes the emissions test it's all good.
Old Dec 25, 2002 | 06:24 PM
EvilGSR's Avatar
EvilGSR
i had to cut mines cause the jdm itr headers wouldnt fit.
As you can see i had 7in. cut off of the high-flow!
