Accessing Climate Control bulbs?
Old Dec 22, 2002 | 12:47 PM
macross81's Avatar
macross81
Default Accessing Climate Control bulbs?
Hei, I am attempting to replace a burned out bulb under the a/c section of the climate control on a 96 Integra LS. Does anyone what's required to remove this area? I don't want to break anything in the process. Any help would be appreciated.
Old Dec 23, 2002 | 08:54 PM
Psychosis's Avatar
Psychosis
Meber
Pick up a haynes/chilton manual... should explain it pretty well.
I have the same problem, one of these days I gotta fix that damn thing :/
Old Dec 25, 2002 | 02:26 PM
98Civichb's Avatar
98Civichb
To take off your climate control, you pop off the Hazard and Defrost buttons with a screwdriver (be careful not to break anything) and then I think there are a couple screws in there. Then you just pop the whole thing off.. I forgot if there are bulbs under there though hehe
Old Dec 26, 2002 | 05:19 AM
SimplyFast's Avatar
SimplyFast
I'm like dis...
you also have to disconnect the cable that hooks to the hot/cold slider.
