Stock RS flywheel weight?
cryoteknical
used ITR flywheel worth $64 for 3 lbs less?
Ok so I know the ITR is 15 lbs, the GS-R is 18 lbs, but nowhere have I been able to find the RS flywheel weight, anybody know this?
cryoteknical
Thanks
I can get a used ITR flywheel for $64 is that 3 lbs difference worth it? Also am I correct in assuming the ITR one can just bolt right up? It will be used with the ACT HDSS kit.
The ITR one will fit - see if you can get it lightened and balanced to about 12-11 lbs then you're in business. Actually you should just get your stock one lightened. I have a GSR lightened to 12lbs and its fine.
I have a 12lb GSR one (I picked it up already lightened so I dont know how much it costs) and its been on a modded and nitrous RS motor that gets driven hard with a centerforce dual friction clutch with no problems what so ever. I wouldnt go lighter than 12-11 in my opinion though.
