Breaks
Old Dec 11, 2002 | 05:54 AM
TotoTeg's Avatar
TotoTeg
Default Breaks
I just replaced the roters and pads on my 94 ls, and now when i break I have to go to the floor to slow down, any Ideas?????
Old Dec 11, 2002 | 06:11 AM
b00gers's Avatar
b00gers
its brakes. and did you bleed the lines?
Old Dec 11, 2002 | 06:13 AM
TotoTeg's Avatar
TotoTeg
yes I Did
Old Dec 11, 2002 | 06:46 AM
90'RS's Avatar
90'RS
did you have any type of problems with the brakes being soft before the change? I would suspect that you need to bleed them better.
Old Dec 11, 2002 | 08:04 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Antarius had a similar problem with his powerslots; you might want to search for his post.
Shingo
Old Dec 11, 2002 | 08:19 AM
chewie's Avatar
chewie
what kind of brake fluids did you use?
Old Dec 11, 2002 | 08:51 AM
XSrcing's Avatar
XSrcing
also, did you give them time to break in properly? when you get new pads and rotors, they tend not to work very well untill after a couple hundred miles.
Old Dec 11, 2002 | 08:55 AM
mrhonda_187's Avatar
mrhonda_187
Yeah, but 'to the floor'? That's just plain dangerous. Doesn't sound like a break in problem. I'd say air in the lines... but let's see what Antarius' post yields.
Old Dec 11, 2002 | 08:57 AM
XSrcing's Avatar
XSrcing
well true. and are your brake lines in good shape? they could be expanding to unreasonable amounts, but that shouldnt cause the pedal to go to the floor. most likely the brakes werent bled good enough.
g2tegls's Avatar
g2tegls
MR, ftw
Get speedbleeders man those things rock da hizzouse. :thumbup:
It might also be the master cylinder but if it just started after you changed the brakes then chances are about 99% that it's air in the lines.
