Best Turbo for GSR
Old Dec 10, 2002 | 11:22 AM
solfreak's Avatar
solfreak
Default Best Turbo for GSR
As you can probably guess, I am wondering which turbo would be the best for a GSR when you want to run anywhere from 7-10psi. Yea... this is opinionated stuff, but all dyno charts or other stats would be awesome and help a bunch.
Old Dec 10, 2002 | 11:53 AM
XSrcing's Avatar
XSrcing
i would have to say greddy with FMIC, revhard, or DRAG. hmmm...seems like i've covered all of them. oh wait! i have an idea! use the button at the top right!!!
Old Dec 10, 2002 | 12:18 PM
Altered_Ego's Avatar
Altered_Ego
revhard
Old Dec 10, 2002 | 12:50 PM
lttletimmy's Avatar
lttletimmy
I'm no expert at turbos, but from what i hear Greddy is better for low-boost applications like that and revhard and DRAG are more for higher boost purposes
Old Dec 10, 2002 | 09:15 PM
jlammy's Avatar
jlammy
w00t
Greddy is good...instructions on that is ok....Drag3? LOL...that shiat has little or NO intructions. The check valves on those kits are ghetto too...oh well You get what you paid for. Then again, I can't justify spending about $2500-$3000 for a Greddy kit only to fork out another $700-800 for a FMIC
Jimmy
Team B.O.B.™ - Ballaz on a Budget
R.I.P Huan Vo 11-19-2008
Old Dec 10, 2002 | 09:19 PM
dubcac's Avatar
dubcac
I
Greddy. It will spool faster, and if you only want to boost 7-10 lbs you'll be fine with the smaller turbo. Not to mention the quality of the Greddy kit is much higher than drag/revhard; it comes with everything, every nut and bolt that you need to get running.
Old Dec 10, 2002 | 09:48 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
7-10 psi I say Greddy.
Shingo
Old Dec 10, 2002 | 09:56 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
GReddy is better as an all-in-one solution. It comes with higher flow rate fuel injectors and a preprogrammed piggyback computer to work around your stock ECU (on '96-'99 cars olny).
If you're willing to put a bit more work in and add some parts the Drag3 and RevHard kits are good starting points.
Old Dec 11, 2002 | 04:08 AM
newgsrdriver's Avatar
newgsrdriver
And anyone who is going FI is going to go down that road. You will want more boost....it doesnt just "end" with a turbo kit, as much as everyone would like to hope
I say Drag. Why? The kit is pretty versatile for when you want to up the boost, it doesnt come with that stupid bluebox shiat, you can find them used for cheap....Drag is the way to go IMO.
Old Dec 11, 2002 | 01:01 PM
Lastgsr's Avatar
Lastgsr
WoOo WoOo
what about this kit? the maxrev groupbuy on ht.... maxrev kit with either the s100 or s200 hondata. Is anything additional needed to run the kit?
