i have koni yellows with h&r sports, i was just wondering if it might be bad at all on the shocks if i always drive with them on their stiffest setting with the sport springs?
You should never drive them on the stiffest setting. You're supposed to crank it up all the way, then go back a quarter turn. You will damage your shocks.
I forget off hand exactly how the adjustment works, but it involves a valve. And that the valve should always be at least 1/8 of the way open or else bad things will happen.
Originally posted by crash it would be all the way open if it was on the stiffest setting right?
Judging from what MrFatBooty said, I'm thinking it'd be all the way closed. You can run them on the softest setting no problem. Technically the shocks are infinitely adjustable; I usually go one turn from full soft to 1.5-1.75 turns.
