Cruise control problem
Old Nov 29, 2002 | 11:55 AM
bucash's Avatar
bucash
Default Cruise control problem
My cruise control goes in and out. Some days it works some days it doed not. Anyone have knowledge on why this would happen. I have a 96 I would nor expect the cruise to go out already
Old Nov 29, 2002 | 12:35 PM
ur31337's Avatar
ur31337
Colby
What do you mean? Are you having trouble engaging it or is it just coming out of cruise control during a cruise. You have to be accelerating for it to work I'm pretty sure.
Old Nov 29, 2002 | 12:37 PM
fanatic's Avatar
fanatic
Your question is too broad, it could be numerous things. It could be the harness, the actuator, the switch, the computer, or one of the safety cut-off switches. You need to check all of them(see if the owner's manual says anything too).
Old Nov 29, 2002 | 12:42 PM
kfar09's Avatar
kfar09
the same thing happens on my 96 too. i dont know if urs does this but some days i push the cruise button in and then hold down set and it sets, but then other times i try to do the same thing and it doesn't work. i was curious of how to fix this as well
Old Nov 29, 2002 | 12:46 PM
fanatic's Avatar
fanatic
This may sound stupid, but doesn't the car have to be going more than like 30 for the cruise to engage? Cause that might be something to notice.
Old Nov 29, 2002 | 12:57 PM
kfar09's Avatar
kfar09
well i have set it on 25 before j/ messing around but i try and set it at 80 and it doesn't work
Old Nov 29, 2002 | 05:49 PM
Chrgsr96's Avatar
Chrgsr96
I have a 96 and I have that exact same problem, except I think I may have done something to caues it to do this. A while ago I was sitting in my car with the keys in the ignition and that stupid jingle was going on and wouldn't stop just cause my door was open.
Well me being the dumass that I am took out the starter signal fuse so it would stop. Well it stopped, but so did my rear defroster, the first speed on my windshield wipers, all of my interior dome lights, and the cruise control would only work everynow and then. So I was like hmm I'm putting that fuse back.
So I put the fuse back and nothing came back!!!...I checked to see if any of the fuses were busted, if I had put the wrong powers in like a 15 instead of a 20, and everythign was perfect. I have no clue what is wrong and it only went wrong cause I took out that fuse. Does anyone have any clue as to what the heck I did?????????
Old Dec 1, 2002 | 07:54 AM
bucash's Avatar
bucash
My cruise worked last night. But then I tried it this morning and it would not engage. When it engages everything works perfect. What is the safty cut off switch? Will your car not go into cruise control if a number of other thing ore wrong with it?
Old Dec 1, 2002 | 09:57 AM
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
this may be lame but maybe one of ur pedals is stuck down slighty...this may cause the cruise control not to engage...my clutch pedal is down a little in it's free movement area so mine won't engage.
Old Dec 2, 2002 | 05:57 AM
bucash's Avatar
bucash
I have the original clutch so nothing has ever been done to the pedal and it is very tight so there is no give on the pedal so I dont think that is the problem. I am still wondering what the safty cut off is?
