best engine to fit my teg
whats up everybody i have a question. first off if i wanted to be able to put between 6-700 whp down what motor would i need to build up and drop in(94 integra)preferably without turbo . and i dont want a new car.thanks for any help
I hate 2003 Noobs.
Unless your building a drag car your not going to find 6-700 whp on a daily driver honda. Also if your dumb enough to think you can make 6-700 hp na on 1.8l you shouldnt think about turbo.
hey txhatch read and re read what i said dumby any engine and i prefer not to have it but that does not mean i wouldnt use it. and check out streetimports.com search around for a 1993 civic ex with a b18 from a teg sportin a turbo runnin 600hp jackass
Irisher than Thou
Highest (Daily Driver) turbo Teg I've heard of was in SCC, there was one with 450 whp or something like that. Had crazy work done to it, running at big (for a honda engine) PSI. There's an integra drag car that has 1300 hp or something. But, the only thing about it that's true Integra is the headlight shape. The engine is a Chevy 350 cut in half. It runs a twin turbo set up and nitrous, and ruins the engine block after almost every run.
Irisher than Thou
I looked around at both streetsports.com and streetimports.com and didn't see anything with numbers on any car :dunno: You have a quote or something about the 600 hp civ?
I hate 2003 Noobs.
I saw the car he was talking about and i would want the specs on that thing. It looks like it may be powerful, but somethings dont look right. The turbo looks too small, it looks like a t3/t04, also i dont see how they could make that much power on the turbo manifold they are using. :bs:
