Seized caliper pin! Is there anything I can do?
Old Nov 20, 2002 | 06:48 PM
g2tegls's Avatar
g2tegls
MR, ftw
Default Seized caliper pin! Is there anything I can do?
Besides replace the caliper bracket? I tried turning the pin using a locking pliers but it ain't movin. I also tried pounding on it with a hammer to make it go in or brake it loose. No luck. Any help? Thnx.
Ben
Old Nov 20, 2002 | 07:15 PM
XSrcing's Avatar
XSrcing
happened to my rear caliper once. so i drenched it with PB Blaster and let it sit over night. then i locked some vise grips on the pin so the whole thing looked like ^. then i set it on a piece of wood and started pounding on the highest point with a 12 pound sledge hammer. after about 10 hits it started moving. then it just took alot of twisting to get it out. after i got it out, i used a dremel with a wire brush cut down in diameter and more PB Blaster to remove all the rust from the inside of the guide pin sleeve. put a very generous coating of grease, then put it all back together.
Old Nov 20, 2002 | 08:53 PM
g2tegls's Avatar
g2tegls
MR, ftw
holy crap. i don't have a sledge hammer.
Old Nov 21, 2002 | 08:58 AM
XSrcing's Avatar
XSrcing
see if any of your friends have one. if they dont, they aren't very expensive.
Old Nov 21, 2002 | 01:26 PM
g2tegls's Avatar
g2tegls
MR, ftw
Welp, I soaked it in PB overnight but it still didn't come loose in the morning. So I went to the parts store to see if they had caliper brackets in stock and the guy there was able to get it out using an electric impact wrench (after like 20 minutes). Thanks for your help though.
Old Nov 21, 2002 | 02:10 PM
LT's Avatar
LT
The deer had to die!
never had a problem with mine...hm...great that you got it out!
Old Nov 21, 2002 | 04:20 PM
fastb18c's Avatar
fastb18c
Same thing happend to me- had to have the rear caliper rebuilt, not to mention had to re-true the rotor and replace the pads. I feel good that's I'm not the only one to have this problem though...
Old Nov 21, 2002 | 04:24 PM
XSrcing's Avatar
XSrcing
its cool the guy helped you get it out. everyone here said i was SOL. so i had to prove them wrong.
