noise while turning the steering wheel??
Old Nov 27, 2002 | 04:29 PM
g2tegls's Avatar
g2tegls
MR, ftw
I'd also check the power steering belt tension
Old Nov 27, 2002 | 09:26 PM
JEFFOS69's Avatar
JEFFOS69
I know the sound your talking about -its like a metal rubbing kind of squeak? It apparentsly happens to alot of tegs you just have to get under the car and grease up a certain part.
Old Nov 28, 2002 | 07:41 AM
gc94GSR's Avatar
gc94GSR
Roving Member
I have experienced this same problem.
It is an interior squeak that only occurs when turning the steering wheel. For me it only happens once/a couple of times after starting from a fully cold start and then stops after the interior warms up.
I suspect that some lube in the right place will get rid of it but since it doesn't happen very often, it doesn't annoy me all that much.
Gordon.
Old Nov 28, 2002 | 07:51 AM
mrhonda_187's Avatar
mrhonda_187
My buddy's Accord does the same thing. Sounds like pigeon's 'cooing' every time he makes a turn. His has gradually progressed from 'doing it only when cold' to 'doing it ALL THE TIME, regardless of temperature. Very annoying. Thanks for the suggestion Shoofly... hopefully the Integra and Accord steering columns are similar.
Old Nov 28, 2002 | 08:57 AM
ur31337's Avatar
ur31337
Colby
I've got the same issues, and I just had my oil changed. The dealer checked it out, my friend is the lead tech, and he didn't notice anything strange. He said next time my oil change is due, to leave it all day and they'd check it cold.
Old Nov 28, 2002 | 04:12 PM
ITRraceR's Avatar
ITRraceR
well just got back from the dealer , shoofly was right the steering column just neede some grease but now it works just like new lol
Anyway good thing i went to check it out i also found out that my master clutch cilinder is leaking and acura will replace it for me ( warranyt ). So its good to go for a little check up to a dealer once in a while especially if you got hookups there lol
Old Dec 28, 2002 | 03:46 PM
drdavidge's Avatar
drdavidge
does anyone have any pics of exactly what to grease up? i got this problem too.
Old Dec 28, 2002 | 04:56 PM
SlowIntegraGSR's Avatar
SlowIntegraGSR
check your steering fluid first see it is low. If not then probably you powersteering pump.
Old Dec 28, 2002 | 06:01 PM
kfar09's Avatar
kfar09
this just happened to me tonight when i started my car after working for 10 hours. but it only happened when i turned the wheel all the way and when it was anywhere else, there wasn't the "screeching sound". all my fluids seem to be full. think its the same thing? hopefully nothing serious
Old Dec 28, 2002 | 10:45 PM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
that happened to me also, i took it to the dealer and he told me that something has to be greased up again, and the problem stopped, i forget what had to be greased up though.
