Turbo+Injectors question.
Old Nov 14, 2002 | 11:13 PM
Vince's Avatar
Vince
*Uncle Ben's best friend*
Default Turbo+Injectors question.
Venom injectors, are they any good for Turbo. Or should I go with another brand??
Old Nov 15, 2002 | 08:15 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You need to buy injectors based on their flow rate, not brand.
Old Nov 15, 2002 | 08:30 AM
antarius's Avatar
antarius
Large Member
True dat.
I'd go RC Engineering, 370's or 440's if you're gonna be running a lot of boost. (over 7-8psi).
Old Nov 15, 2002 | 11:09 AM
Vince's Avatar
Vince
Well i plan on running 7 psi, so you think i'd be better to go with RC? Don't they make custom injectors specific for your application? Is the price much higher for RC than Venom?????
Old Nov 15, 2002 | 11:58 AM
antarius's Avatar
antarius
Large Member
You'll spend about $300-400 for RC Engineering INjectors.
I'd get 370's (from RC Engineering).
Old Nov 15, 2002 | 12:02 PM
Vince's Avatar
Vince
Thanks Antarius, i'll check it at my local dealers.
Old Nov 15, 2002 | 12:03 PM
antarius's Avatar
antarius
Large Member
Look at groupbuycenter.com too -- just be careful for shady shops.
Old Nov 15, 2002 | 12:22 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
If you want to save some money you can get some dsm injectors and get their cleaned and blueprinted. You'll need to put in some inline resistors or get an old resistor box from an old accord or crx. You have to change the clips on the injectors too but in the long run you save lots of money. Total cost ~120 as opposed to ~280 for new rc's. Remember with injectors this big your stock ecu cannot control them so you'll need an afc or any stand alone will do.
Old Nov 15, 2002 | 01:43 PM
newgsrdriver's Avatar
newgsrdriver
Total cost of my DSM 450 setup? $58.62.
What you need?
-DSM 450s off of a DSM Turbo 5SPD (must be stick)
-Resistor box from older Prelude/CRX/Accord, etc, or 4 10ohm, 10watt resistors from Radio shack (come in a pkg of 2 for 1.69 ea).
-DSM Injector Clips (if youre obd2)
Its cake. There are two wires coming from each injector, a colored wire and a yellow/black. Just solder in a resistor in between the yellow/black wire of each injector, and youre done. If youre OBD1, just snip off the nipple in the Honda injector clip (a la 9005 conversion) and plug n play, no other clip needed. Otherwise, you can just snip the Honda clips off and solder on the DSM clips.
RC Cost? $300+
DSM Injectors? $50. Cleaned/Balanced/BP'd? $25.
My only gripe is they are loud as hell. They tick like....a really loud injector
Old Nov 15, 2002 | 01:52 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Nick: Whered you get em cleaned and blueprinted for 25 bucks? Cheapest place i've seen is cruzin for 11 bucks each. And btw 50+25 = 75 not 58.62 hehe
