Installing Spoon strut tie into DC2 hatch.
Old Nov 1, 2002 | 11:25 PM
coil222's Avatar
coil222
Default Installing Spoon strut tie into DC2 hatch.
Do I have to remove the plastic in the back to get it on.
I think I do but I don't want to if I Don't have to.
Old Nov 2, 2002 | 02:07 AM
evo119's Avatar
evo119
GO GIANTS!
yea of course, that's where the upper strut mounts are......
Old Nov 2, 2002 | 03:03 PM
coil222's Avatar
coil222
Not the little removable panels, but the whole trunk liner.
Old Nov 2, 2002 | 03:22 PM
DB7 2.0's Avatar
DB7 2.0
Banned
i think youre going to have to cut a tiny piece of it off (the plastic) .. no big deal and fairly easy to do.
Old Nov 2, 2002 | 04:51 PM
evo119's Avatar
evo119
GO GIANTS!
As far as i know...all you need to do is remove the plastic panels. I used to have a skunk2 rear strut bar, and that's all that's required. No cutting at all or removing anything else, unless the spoon bar won't clear it, which I'm almost sure it will.
Old Nov 2, 2002 | 05:04 PM
Deagle's Avatar
Deagle
Nüb
There's a piece of plastic that bridges over the left shock tower. Did you have to cut that off? I've also got a Spoon bar on order. I guess it doesn't matter; if it's in the way it's coming out regardless.
Old Nov 3, 2002 | 12:23 PM
coil222's Avatar
coil222
installed
Didn't have to cut the plastic on the left shock tower.
Just had to pull the plastic trunk liners out and slip the black pieces in then bolt them down.
Easy.
