transmission query...
Old Nov 1, 2002 | 02:09 PM
LT's Avatar
LT
The deer had to die!
Default transmission query...
hey, i'm gonna be getting a gsr motor for my LS, however the tranny case on the GSR is cracked so i need a new transmission for this other motor.
Can I put the LS tranny to the GSR motor (new gears are in the GSR tranny, btw!)?? i have all winter before this GSR motor mates to the LS body.
Any help is appreciated!
Old Nov 1, 2002 | 02:40 PM
lttletimmy's Avatar
lttletimmy
yes, it will work but it won't be ideal. You'll loose a bit of acceleration in the gearing but it should bolt up and work no problem.
Old Nov 1, 2002 | 02:53 PM
TheRooster's Avatar
TheRooster
Former Senior Member
If its just the housing that's cracked, you can take all of your GS-R guts and put them into an LS housing. While you have all of your shafts and such out (which would be good to check to make sure all the clearances are stellar) it would be also good to drop in an ITR differential. Used ones can be picked up off of eBay for around 300-400 bucks. You can effectively kill two birds with one stone, and not lose the shorter GS-R gearing. I've got some pictures and such of the guts here:
Http://photos.yahoo.com/the_rooster_dont_die/
If you want more in depth info on swapping everything over, let me know.
