Water in the trunk
Old Nov 1, 2002 | 08:49 AM
parsamkk's Avatar
parsamkk
Default Water in the trunk
Hello gang,
I have a small problem. I drive Integra RS hatchback. When in rains hard a get some water in the trunk. Does anyone have an idea where is it coming from what can I do about it.
Thanks !!
Old Nov 1, 2002 | 08:55 AM
lttletimmy's Avatar
lttletimmy
check teg tips at www.g2ic.com. Check your trunk liner, where water is supposed to flow down. If it's stopped up with some debris, that could be all that's causing it.
Old Nov 1, 2002 | 09:04 AM
LT's Avatar
LT
The deer had to die!
join the clubs of thousands of teg owners with that problem. Gaskets between the taillights and the body can deteriorate enough to allow water to leak thru as well.
Old Nov 1, 2002 | 11:36 AM
Xyooj's Avatar
Xyooj
just took trunk body panels off... I found out that my drain line was loose.
Old Nov 2, 2002 | 10:18 AM
parsamkk's Avatar
parsamkk
What the hack is a drain line and where is that.
I think the reason is the in the lights.
Thanks for the help.
Old Nov 2, 2002 | 11:00 AM
Myztikal's Avatar
Myztikal
2000 Prelude Type SH
EXACT thing happened to my 99 Integra LS hatchback
WHen it rains hard, water gets into my trunk . Yesterday I just cleaned it up and I stuffed my trunk with my old shirts so when water gets in it again it will soak it up and not ruin anything.....
Old Nov 4, 2002 | 07:36 AM
aktano's Avatar
aktano
My GF's car has the same issue. What/where is the drain in the trunk you speak of?
Old Nov 4, 2002 | 08:17 AM
chicagovelocity's Avatar
chicagovelocity
raw dawgin'
my trunk is a swamp
**** comes in from the top of the tails, and leaks in thru the spaces :\
Old Nov 4, 2002 | 07:53 PM
boojee's Avatar
boojee
same thing happens to my 1994 ls. It is not to bad but the cardboard covering is starting to get warped by the water?
Old Nov 5, 2002 | 09:37 AM
LT's Avatar
LT
scrap-yard time for this LS!
