coilovers vs. springs
OK coilovers have the advantage of customable heights but is the ride and/or performance the same as lowering springs? I am looking to upgrade my suspension, I think I am going to get KYB AGX shocks but haven’t decided on this springs yet? I don’t want to lower to greatly but ride is much more important then .5 of an inch. Any suggestions or comments on your experience on coilover/springs? Thanks in advance
Most street springs have progressive spring rates; coilover sleeves such as Ground Control use linear spring rates = worsened ride quality but better handling. However, the cheaper coilover sleeves/systems are not worth buying period.
It really depends on how much you want to spend. I have adjusted my ride height several times since I put on larger wheels (fender rubbing problem). My shocks are adjustable (rebound only) so I've tweaked with them during track days and whatnot. I'm definitely a proponent for some degree of adjustability, but if you're aiming to spend less than $300 a good set of springs will do you best.
Shingo
Shingo
Large Member
I didn't read your whole post or the replies, just mainly the topic... so if I'm off base, then sorry. Here you go...
I'd say coil-overs.
I have Ground Control Coil Overs and I can't tell you how nice it is to be able to raise or lower your car, this corner this way, this one this way, yadda yadda, just to make it PERFECT.
Yes, technically you have to get an alignment after you adjust the height, but I've never gotten one and my tires are wearing just fine.
My GC's dont ride any worse than my friends Prelude with Neuspeed Springs and KYB AGX's.
I'm on GC's and Koni Yellows.
They handle every bit as well/better than a spring setup.
COil Over!
I'd say coil-overs.
COil Over!
I get custom user text?
Well technically GC and Skunk aren't coilovers, they're adjustable springs, true coilovers are a strut/spring combination, companies like JIC, Koni, and Tein make true coilovers
Roving Member
From my research, the least drop you can get from an off-the-shelf spring is 0.75 inches from both H&R OE Sport or Neuspeed SofSport springs.
I'm planning on going with H&R OE Sport and Tokico Illuminas myself but I'm going to wait until spring. I'd like to go lower but need adequate snow clearance in the winter.
Gordon.
Gordon.
