Need Help tonight, sway bar
Old Oct 3, 2007 | 11:46 PM
Spec R's Avatar
Spec R
ouch, my ITR sway bar install with beaks kit took me a long ass time to install also, but because i had all the wrong tools and cheap hand tools.
dont know specifically about that asr kit not lining up.
the spot welds on the koni's i had broke too. i just used longer shock bolts and a nut on the other side
DB Squad
Integra Forum Moderator
Old Oct 3, 2007 | 11:58 PM
Snoopy's Avatar
Snoopy
been there done that
you need to drill out the holes i believe
http://www.kingmotorsports.com/image...604.pdf?476676
Old Oct 4, 2007 | 12:52 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
I did a itr sway on my buddies gsr. It was a bitch
Old Nov 20, 2007 | 02:08 AM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
For anyone that cares I said I would post pics so here they are. You can see where I had my problem with the sub frame being bent. Also a question... What should I do about the hanging brake lines?
Old Nov 20, 2007 | 08:06 AM
jesusublime99's Avatar
jesusublime99
Looking great! How does it feel?
If possible, zip-tie the brake lines to top of the lca's. You don't want those hanging low.
Old Nov 20, 2007 | 03:43 PM
Spec R's Avatar
Spec R
remove the metal brackets by bending back the little tabs.
then just use zipties.
they're not "brake" lines per se, as there's no fluid going thru them, but they are your wheel sensor wires for your ABS system
DB Squad
Old Nov 20, 2007 | 05:54 PM
2001TEGGSR's Avatar
2001TEGGSR
So what exactly is the story with your subframe? Was it bent, or did you need to modify the ASR brace?
As for the brake lines, I did exactly what Spec R suggested.
Looks good!
Old Nov 20, 2007 | 11:09 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
I'll try the zip-ties. As for the sub frame I was stupid and thought i could use it as a jack spot. I bent it, but I fixed it by using a C clamp and a small piece of wood it does feel better but I thought it was going to make alittle bigger difference. I was thinking about trying to paint the ASR red so it will stand out alittle bit more. What do you guys think?
Old Nov 20, 2007 | 11:17 PM
Spec R's Avatar
Spec R
paint it the same green as your car. that would look better than red
DB Squad
Old Nov 21, 2007 | 12:02 AM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Do you think the green would look good with it being black?
