Maintenance Required light!!!
Old Oct 14, 2002 | 09:35 AM
jeems's Avatar
jeems
i be slow
Default Maintenance Required light!!!
When I start my car now the maintenance req. light blinks like 10 times. what is the deal? my light has come on before back in the day but i dont think it blinked, it just came on and stayed there for a minute.
Old Oct 14, 2002 | 09:40 AM
b00gers's Avatar
b00gers
its a periodical (sp) light...it comes on after so many miles...
there is a square button under your dash above your knee, hold that button in while you start your car. it should go away.
its there to tell you that its time to change your oil at the dealers.
Old Oct 14, 2002 | 10:32 AM
timmy8151's Avatar
timmy8151
Read this:
http://team-integra.net/sections/art...?ArticleID=164
Old Oct 14, 2002 | 11:26 AM
jeems's Avatar
jeems
i be slow
well i guess i forgot to mention that the same day that the light came on, i also went over redline on the tach.
Old Oct 14, 2002 | 11:57 AM
bchap's Avatar
bchap
Default push and hold
Just push and hold the button until light goes off. Sometimes as long as 30 seconds. No problem on exceeding redline. Almost a daily occurence for me. 175000 miles and counting.
Old Oct 14, 2002 | 12:09 PM
lukethenuke's Avatar
lukethenuke
i would maybe suggest checking the fuses. I had a similar problem where i took apart the dash and when i put it back together some of the lights on the guages were flashing. AFter though when i replaced some of the fuses it everything worked perfectly.
Old Oct 14, 2002 | 12:13 PM
kento's Avatar
kento
it has nothing to do with the fuses... it comes on every so many thousand miles... just push the button above your right knee as everyone else mentions, while your car is on, and it will go away.
Old Oct 14, 2002 | 05:05 PM
lukethenuke
okay then it isn't the fuses push the button as everyone says
Old Oct 14, 2002 | 05:08 PM
bchap's Avatar
bchap
Default Button under Dash
Isn't this covered in the manual?
Old Oct 14, 2002 | 05:37 PM
antarius's Avatar
antarius
Large Member
Yes, it's in your service manual.
There's a button right under the steering column, kind of on the right side.
It's a small square button.
Put the key in, hold the button, and turn the key to the ACC setting.
It will go away.
