Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   Integra & 97-01 Integra Type-R (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r-17/)
-   -   won't start when engine run hot (https://www.honda-acura.net/forums/integra-and-97-01-integra-type-r/276366-wont-start-when-engine-run-hot.html)
tmtran73 Aug 24, 2007 08:05 AM
I have 95 integra se. Just the past 2 days it has problem that it won't start when it get cut off after 30minutes drive or more but it run fine when it is already start. Any idea what is the problem???? Thanks for any help you can.
BTW, dis cap, rotor, spark plug, and wire are just replace about 2 month.
v6_accord_jerz Aug 24, 2007 09:39 AM
Having a hard time understanding your description. So you're saying it starts up and runs fine but after a 1/2 hr it shuts off???
Check your main fuel relay, it might be faulty. Also could be a bad ignition switch.
tmtran73 Aug 24, 2007 09:48 AM
I mean, if the car started it runs fine no problem. The only problem it is when stop and turn off the car (turn ignition switch to off position), it won't start again.
v6_accord_jerz Aug 24, 2007 12:01 PM
Have your starter checked at an autoparts store (Autozone), even Sears does it too. Most likely you'll have to replace it.
tmtran73 Aug 27, 2007 10:06 AM
I sorry to mention this at my previous reply that when I re-start the car after cutting off the engine (engine is hot), it does do the spinning but not start. I just wonder could it be the distributor, control module, ignition coil, spark plugs (plugs just replace about 2-3 months)???? The ECU ligth is not lid but I did to check and did not find anything. Please help.
Wharbone Aug 27, 2007 02:14 PM
Sounds like your main relay to me.
Turn your key to the "on" position. The check engine light should come on for about 2 seconds and go off. Also, you should be able to hear your fuel pump prime from under your rear seat. If you can't hear it prime, theres a good chance it is your main relay.
The problem is caused from dry solder joints in the relay. If you are good at soldering, you can actually fix the part yourself.
I have posted links regarding this before. Search for it under my name.
tmtran73 Sep 11, 2007 09:48 PM
Wharbone,
I can't find your thread which has the link on how to fix this problem. Please re-post it again.
Also, I've checked the Engine Light, it does exactly what you mentioned above (on and off within 2-3 second). The same thing, when I turn to the on position, I hear fuel pump prime from the back seat.
The problem seem gone now. I have not done anything other than replace the fuel filter. It is weird that the problem still there for the whole day after the fuel filter was replace but now it is gone. Maybe the weather is the cause of the Main Relay. Do anyone have the instruction how to locate/replace the Main Relay on 95 Integra SE?? Thanks for any help.
tmtran73 Sep 17, 2007 08:14 AM
can anyone help with where is the main relay in 95 integra se and how to fix/inspected?
MostlyShow Sep 17, 2007 03:56 PM
On the Civics it is located directly above the handle that "pops" the hood, near the driver's left foot. You will need a limber spine, patience and a 10mm box wrench.
If you would like, you can download the Integra's shop manual here
Best of luck!
The site may be of help too. It discusses at length the problems and solutions of the Honda main relay.
zetune Oct 12, 2007 10:00 PM
Main relay usually causes a problem when cars interior is hot. Doesn't matter what temperature the engine is.
I am having the same problem on my accord (89). And its definitely not the relay. I replaced the cap, rotor, plugs, and wires. Didn't fix it. Re-built the distributor... didn't help. Changed the ignitor, didn't help. I am going to follow someone elses advice and change the collant temperature sensor and ignition coil. If that doesn't work I am going to try jumping off a bridge. That ought to do it.
© 2026 MH Sub I, LLC dba Internet Brands
