Exterior Door handle
Old Aug 19, 2007 | 07:40 AM
x6against7's Avatar
x6against7
Default Exterior Door handle
I'm trying to pull out my exterior door handle and can't. I can't get the acuating rod detached. Is there any special way to get it off. All the haynes manual says it to detach it.
http://s55.photobucket.com/albums/g1...insidedoor.jpg
http://s55.photobucket.com/albums/g1...nt=topdown.jpg
I've got to get this done today! please help
Old Aug 19, 2007 | 06:16 PM
Fuse's Avatar
Fuse
Spray it will penetration oil alot. Use a flat head and pry the rod out. This is a big pain it may break on some of the older cars no way around it its plastic.
Old Aug 19, 2007 | 06:30 PM
A-series's Avatar
A-series
v-card member alpha
Otherwise you could just give it some time, they tend to break by themselves once the actuator starts acting up (dirty/corrosion/no lube).
Old Aug 19, 2007 | 06:54 PM
x6against7's Avatar
x6against7
Heres the deal I got a new door after being hit and want to switch out the old lock into the new door. So if they break can i get new parts, or is it a hole assembly?
Old Aug 19, 2007 | 07:08 PM
Fuse's Avatar
Fuse
Hole assembly but you can brake one just not the other. You can swap lock assembly's but its easiest with the handle out.
