brakes
Old Aug 13, 2007 | 03:10 PM
miggz ls's Avatar
miggz ls
Default brakes
my rear right brake are stickin. Nasty smell any ideas wat it could be
Old Aug 13, 2007 | 03:21 PM
TaleTEGaNights's Avatar
TaleTEGaNights
maybe a ceased caliper, when was the last time you had your brakes done or looked at? have you taken them off yourself to take a look at them?
-A
Old Aug 13, 2007 | 03:28 PM
miggz ls's Avatar
miggz ls
i replaced the brakes about a year ago. But i replaced the rotors my self. the calipers looked pretty hurt. The rubber around the piston was torn apart
Old Aug 13, 2007 | 03:34 PM
TaleTEGaNights
you may be lookin at needing new calipers then.... I was lookin into it a while ago, I dont knwo where your from but i live in Ontario and there are a few places around theat rebuild them...
-A
Old Aug 13, 2007 | 03:42 PM
miggz ls's Avatar
miggz ls
IM from lancaster pa. Auto parts sell remanufactured caliper for about 70 bucks. THANKZ
Old Aug 13, 2007 | 03:46 PM
TaleTEGaNights
np
Old Aug 13, 2007 | 04:46 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I would also check to see if the e-brake is properly adjusted also, I had the same problem. Also, you should replace the pads since they heated up like that, they could crack and fall apart with time. Has the rotor turned cherry red after a drive?
Old Aug 14, 2007 | 05:49 PM
CrazyX's Avatar
CrazyX
Default wow...`
My R R caliper was messing up too for a bit...but come to find the caliper was there since 1994...lol anyways, you can buy a caliper rebuild kit like i did for about 12 bucks. It's only temporary and its performed better than it did before. it's just a pain to do...alot of patience is required. But i'm trying to save for a nice set of endless brake kit.
Old Aug 16, 2007 | 02:39 PM
miggz ls's Avatar
miggz ls
the rotor wasnt cherry red but it was a nasty smell. IM replacing both rear calipers an pads this weekend. thankzz
Old Aug 18, 2007 | 01:35 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Might as well replace the rotors while you're down there.
