my lights are not working
Old Jul 17, 2007 | 09:04 PM
i.got2!'s Avatar
i.got2!
Default my lights are not working
i have a 97 integra GSR, my emerge...lights stop working but the weird thing is that my blinkers work left and right but not the hazard one is there any one that can help THANKZ
Old Jul 17, 2007 | 09:16 PM
AcuraLsSE's Avatar
AcuraLsSE
ASE Certified
Umm could be a fuse.
Old Jul 17, 2007 | 10:14 PM
i.got2!'s Avatar
i.got2!
i checked fuses and also the (turn signal/hazard relay) everything looks fine anything else in mind Thnkz
Old Jul 17, 2007 | 10:25 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
If the fuses are good and the relay is intact... then the next thing to check is continuity across the switch itself.
Old Jul 18, 2007 | 03:07 AM
Josher's Avatar
Josher
Are the bulbs burned out? I might be remembering incorrectly, but aren't the blinkers and emergency lights two different sets of bulbs?
Old Jul 18, 2007 | 11:57 AM
i.got2!'s Avatar
i.got2!
Default having problems with my emergency lights
I double checked all my fuses, every single one of them lokks good , but can any one get me a good pic of the front blinkers including the wiring harness maybe the sockets are bad?
Old Jul 18, 2007 | 12:03 PM
TheOtherDave™
Apathy Kills
Have you removed the emergency flasher switch and used a multi-tester to confirm that the switch works?
Since you reported that the turn signals work, I doubt the problem is with the bulb sockets.
Old Jul 18, 2007 | 12:20 PM
i.got2!'s Avatar
i.got2!
I hope I make myself clear so that you guys can help me out, I think the relay makes a sound when turning left or right but when I push the emer... button it clicks one time only but they don't keep flashing . One click ...... I don't know if a wire is making bad contact
Old Jul 19, 2007 | 10:25 AM
i.got2!'s Avatar
i.got2!
Default my lights are acting up
and I also notice that my lights get dimed for about 3 seconds when I turn on my head lights
Old Jul 20, 2007 | 09:08 AM
bnuk's Avatar
bnuk
Just glanced at FSM an it looks like the relay is shared between the turn signals and the flasher. It also looks like the relay is the flasher. I know you said you checked all the fuses but because hazards work with out the key there is underhood fuse as well (the 10A one in the middle of the box), did you check that? Also pop out the hazard switch and see if you have 12V on white/green. If so then I would say you switch is bad.
