Damn you, Omnipower!
Old Aug 21, 2007 | 12:23 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Spherical bearings are going to transmit a lot more vibration than even the hardest polyurethane bearings on the market. They can also be a bit noisy.
Unless you're willing to make that trade off, I'd just get a new set of intermediate poly bushings, splitting the difference between OEM hardness and the zero compliance ride you'll get from spherical bearings.
Old Aug 21, 2007 | 01:18 PM
2001TEGGSR's Avatar
2001TEGGSR
Originally Posted by Provocateur
If you are looking to upgrade your LCA's, look into the PIC LCA. I have a link if you want it.
The one thing I like about the new omni's is the ABS line mounting holes. I guess they can be zip tied though.
Is this the link you have? $120 is alot cheaper than the OMNI's.
http://picperformance.com/store/scri...?idProduct=108
Good point on the vibration, I didn't even think about that. If I were to stick with OEM, is Energy Suspension still a good poly bushing? Or is there another brand I should consider?
Now I'm looking at PIC's website and they claim to use "a proprietary spherical bearing with a polyurethane blend" on the "RR Rear LCA's" which looks like the bearing is lined with a bushing. You guys think this would be tolerable on the street or should I just steer clear of the spherical bearings all together?
$240 for the "Race Ready" version.
http://picperformance.com/store/scri...?idProduct=202
Thanks for all the help!
Old Aug 22, 2007 | 02:48 PM
CrazyX's Avatar
CrazyX
hhmmm...i don't have any of those problems with my blox racing LCA's the best part of them is that the bushings can be replaced as needed and also i can install engergy suspension bushings if needed. I highly recommend blox lca's i've had them for over a year and a half and no issues with them whatsoever
File Type: jpg
Old Aug 23, 2007 | 06:46 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The ABS line holes are overrated.
I have this link. It is the same price but if you mention you are from H-T, he will give you 5% off and ship for free.
Old Aug 23, 2007 | 12:20 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
On this one show on Speed tv on Thurs called Finetuned, they put some Skunk 2 LCA on an 94 civic. The cool part was it looked like it had different mounting holes for the sway bar. I have megan racing one on my hatch and i have not had a prob.
Old Aug 23, 2007 | 12:38 PM
2001TEGGSR's Avatar
2001TEGGSR
Thanks for all the info everybody!
I've decided to go with the PIC standard LCA's, I will post pics when I get them.
Do they use the same bushings as OEM LCA's? Or does Energy Suspension make a replacement specifically for the Blox LCA's?
I'm already a little weary of Blox products, other than the intake manifold. Not to say they aren't a good company, I realize the owner used to work for Skunk2, but I just don't want to have the same problems Provocateur had with his Omni's.
Thanks for the link, I have read several threads on HT and PIC seems to be a good, reputable company. I was very tempted to order full coilovers from them, but I like the Koni lifetime warranty.
I took that into consideration, but they also make adjustable swaybar's and endlinks which is essentially the same result. I would rather not gamble with subframe tear out anyway.
Old Aug 23, 2007 | 01:44 PM
CrazyX's Avatar
CrazyX
They use their own bushings and you can currently order replacements as you go that i currently know of. I do knnow that energy suspension doesn't make a specific bit it does work though!
