unable to locate markings on pulley for TDC adjustment
Old Jun 23, 2007 | 06:40 PM
GSR402LX's Avatar
GSR402LX
Default unable to locate markings on pulley for TDC adjustment
i've been looking at cams install and it require rotating to TDC for cylinder 1..it said that there are white marking, paint, on the crank pulley..but i've look all over the crank pulley but unable to locate it..seems like the paint might have chipped off..is there another way to rotate TDC?? the car got like 90k on it..kinda sux when u can't see the paint on the pulley..big set back..can't install cams if u don't know how to adjust TDC..
any suggestion?? i'd like to have the ctr cams install soon..
Old Jun 23, 2007 | 07:27 PM
FooD2000's Avatar
FooD2000
Still Water
Well it's not just paint but on the inside grove of the csp there is a little "chip" cut into it. There should be 1 chip by itself (where the white mark should be) and 3 other chips (red) mark// white marks.
hope it helps a bit.
Old Jun 23, 2007 | 08:12 PM
Snoopy's Avatar
Snoopy
been there done that
use the cam gears. when the arrows are pointing up, cylinder one is at tdc.
Old Jun 23, 2007 | 11:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
:werd:
And then mark the pulley for future reference.
Since you mention 90k miles, if you haven't done so already, it would be a great time to do the timing belt as well.
Old Jun 25, 2007 | 03:23 PM
GSR402LX's Avatar
GSR402LX
cool..thanks guy..
timing belt were change at 70k-ish miles..so it's still good..
i didn't know u can use the cams gear to do that..ok..i'll give that a try..
thanks again..
