Exhaust Leak...cannot find it!
Old Jun 21, 2007 | 04:39 AM
GSRchick714's Avatar
GSRchick714
Default Exhaust Leak...cannot find it!
So I have an exhaust leak, but I cannot find it for the life of me. My car sounds like poo and sometimes when its raining, it sounds like water is getting into my exhaust...and sometimes it sounds rattly :dunno:
I replaced the gaskets and that did nothing and I see no holes/rust. Any advice on a common leak spot or how to find a leak?
p.s. I have a GReddy SP2
Old Jun 21, 2007 | 01:42 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Mine was leaking really bad right at the header/downpipe flange, lol I forgot a lockwasher on one of the nuts and it fell off....the gasket also had a gnarly hole blown in it so I replaced it and it's like a whole new car now.
Old Jun 22, 2007 | 04:50 AM
hodwiththestrip's Avatar
hodwiththestrip
My GS-R
How to find an exhaust leak:You may have to put your car up on stands to do this, if you can't crawl underneath it when it's on the ground. Have a friend get a news paper, or note book, or something. I use a few pages from a news paper. You're going to use the news paper to cover the tip of your exhaust. This will start to get hot, hence the news paper! Fold the news paper a few times until you have a thick square of news paper large enough to cover your exhaust tip. Now you have your news paper folded properly and your friend. Start your car and let it idle. Now have your friend cover the exhaust tip with the news paper and press HARD. His job is to create as much pressure in the exhaust system as he can, he'll build up high pressure quickly, but tell him to keep pressing.While he's pressing against the exhaust forcing the gas pressure to build up it's time for you to crawl underneath the car. You'll be looking at the exhaust system. Feeling with your hands for exhaust spraying out of some hole or flange (Don't touch the exhaust pipe, it will burn you). You also need to be listening. The leak will make a hissing noise, that should help you hone in on the leak. Another thing to look for would be a small black whole, or blackness around one of the flanges.With this simple and cheap method you should be able to find your leak.As for areas prone to leaking, I would check your flex pipe. It's the part of your exhaust that's made out of metal mesh.
Old Jun 22, 2007 | 08:54 AM
GSRchick714
^ Thanks, that will help a lot!
Old Jun 22, 2007 | 03:11 PM
WiseGuyOnCouch's Avatar
WiseGuyOnCouch
Live, Die, & Drive Fast!
also check where quicksilver described, if you have a stock exhaustmanifold remove the heat shield before starting and check there cuz mine cracked all the way around right where the 3 and 4 cylinder exhausts merge. cuz i couldn't find mine for the longest time till i finally got annoyed enough to fiddle with it till i found it!
Old Jun 22, 2007 | 03:43 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Take an old stethoscope, clip the tip, replace it w/aluminum tubing, tape it together and take a listen at all connecting points. A bionic ear works just as well.
