Calculate socket size...
Sorry I mean to say nut...
So like a 10mm X 1.25 describes the inside diameter of the
hole and the 1.25 describes the thread( I think) ...
I'm taking off the struts on a civic, the manual it says a 10M X 1.25 lock nut,
But I use a 14mm socket to get it off the bolt. Is there a way
I can calculate this, or is it a trial and error thing?
Well, dude. If the manual says the NUT is a 10mm nut, you will use a 10mm socket on that badboy.
Now, it's entirely possible the manual is talking about the BOLT and not the nut and the nut is a different size.
Either that, or someone fhucked with your shiz before and put the wrong size nut on there. Well, not wrong; just different size.
"Little, 14mm, different".
The manual doesn't give the outside diameter of nuts or bolts. Only the pitch and length.
edit: I don't think there's a formula or anyway to tell the head size based on the info they give. You could have any head size really.
Okay... thanks.
I just thought there might have been a way to calculate it...
