a/c not workin
Old Jun 9, 2007 | 12:44 PM
123Lizard's Avatar
123Lizard
Default a/c not workin
Tried my ac the other day and it only blows warm air, did a recharge but still nothin, was trying to find the a/c relay/fuse but couldn't find it under the hood or the fuse box. Anyone know what could be the problem?
Much thanks.
123Lizard's Avatar
123Lizard
oh and its a 95 special edition
Old Jun 10, 2007 | 07:36 PM
hodwiththestrip's Avatar
hodwiththestrip
My GS-R
Was there good pressure in your system when you recharged it?
When you turn on your AC do you hear the compressor engage?
Old Jun 10, 2007 | 08:09 PM
123Lizard's Avatar
123Lizard
yep there was good pressure and not sure if compressor was engaging, mind tellin me how i tell?
Old Jun 10, 2007 | 08:35 PM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
yeah honda compressors are notorious for failure... Check to be sure it's engaging.
Old Jun 11, 2007 | 01:22 AM
hodwiththestrip
My GS-R
The simplest way would be to hit the AC button and listen for a sort of clicking, your rpms should drop just a little right as you turn it on, and you might hear a low pitched hum. Or find a friend, open the hood, and with the car running have your friend turn on the AC and you should hear it engage.
But since you had good pressure, that rules out a leak. So the next thing I would do would replace your compressor. You'll have to get the system recharged again after this. There may be some test that a shop could do, to see if the compressor is working, instead of just blindly replacing it.
Old Jun 12, 2007 | 08:17 AM
Zedron's Avatar
Zedron
Turbo B20
i have a compressor for sale. pm me for more info
Old Jun 12, 2007 | 09:48 AM
mberndt's Avatar
mberndt
Huh?
Notorious? Not that I've heard or experienced...
Every Honda I own/owned never had a problem with AC.
Actually, I had my DX compressor custom bolted to the B-series AC bracket for like 5 years with my swap. My car has been thru hell, and if any AC compressor should've stopped working it was mine.
Run off the road, hydrolocked engine, turbo kit, etc.
I only ever had a problem with a leak on the high pressure line, never with the compressor.
Usually if the compressor is not engaging, it means the system is low on refrigerant...
Old Jun 12, 2007 | 12:27 PM
doobiexx928xx's Avatar
doobiexx928xx
B18 Bullet
Find the fuse for the compressor. I bet thats the problem.
Old Jun 17, 2007 | 07:55 PM
123Lizard's Avatar
123Lizard
yep its engaging, could it be the hoses are leaking? or even clogged?
and much thnx for everyone that replied
