Wheels too big?
Old Jun 6, 2007 | 03:31 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by JoePoonani
No way to cure this but to replace your tires with the correct size ones.
There is something else going on here. Stock height with 17's should look lifted and should provide more than enough shock travel to prevent rubbing.
Usually when a shock is blown it doesn't affect the ride height, thats what I've always seen.
Right, but it won't absorb the rebound of the spring and the resulting bounce will cause things to bottom out.
Old Jun 7, 2007 | 05:20 AM
m735is's Avatar
m735is
The diameter of the 205's is 24.3" and the diameter pf the 215's is 24.6". So the height shouldn't be a big problem. The width is only a touch wider, so it should be hitting the fender lip only, correct? If so, maybe you can just roll the fender with a baseball bat to give you the needed clearance.
Old Jun 7, 2007 | 02:54 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Since he has 215-45s I would think it would rub. Usually when people throw 17s on the car they use 205-40 for the tire size. He is using a wider and taller tire.
Precisely, the shock wouldn't be able to absorb the blow of the bump when it's blown. Also, you will notice the wheel bouncing up and down over bumps for an extended period of time.
Since it's just the RR wheel, I would check your bushings and suspension components on that side and compare them to the ones on the LR side to see if anything is bent or if yolu have a blown bushing.
Old Jun 7, 2007 | 04:16 PM
ukrsindicat's Avatar
ukrsindicat
You are right, it only hits the fender lip. So should I just roll the lip?
Old Jun 8, 2007 | 02:43 PM
m735is's Avatar
m735is
I have never rolled a fender lip, so I can't comment on how hard it is or if it will even cure your problem. If it is just the right side, why? Like Mr. Poonani says, maybe you have something worn out on the right side and that's why it's only rubbing there. I would take a close look at your lower control arm bushings, upper control arm (compensating arm) bushings and rear trailing arm bushings. Make sure your shocks and springs are good. Take some measurements and compare to the left side. If you don't find anything out of line, you want to keep the larger tires and the tire is only hitting the fender on the lip, then yes, I would roll the fenders.
Old Jun 10, 2007 | 03:30 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
That's what my buddy did on his 98' GSR shortly before he totalled it It worked well, cured the rubbing and was pretty easy to do.
Old Jun 11, 2007 | 01:07 PM
WiseGuyOnCouch's Avatar
WiseGuyOnCouch
Live, Die, & Drive Fast!
no offense to you people who have rolled the lips of the fenderwell, but that's just retarded IMHO. The only time i would ever roll the lip would be on my race car and that's just b/c the car gets beat up plenty by the other drivers. rolling the lip is just an accident waiting to happen especially with someone who hasn't done it b4. if you're not careful it will come out looking like pure CRAP!
Old Jun 12, 2007 | 08:24 AM
Zedron's Avatar
Zedron
Turbo B20
I have 215-45-17 and the car is dropped to where the fenders are flush with the tires. Only rubs when wheel is cranked all the way in a direction and never rubs from just driving over speed bumps or anything. I have 5 way adjustable illuminas in the front and 4 way kyb agx in rear.
