conversion
Old Oct 10, 2002 | 02:27 PM
reza's Avatar
reza
Default conversion
What's up everyone? Aight I found me the famous type R engine for cheap. The only problem is It doesnt come with the axles. So does that mean I've got to do a conversion with my 94' acura integra since it is a four lug and the R is a five lug or can I just use the axles from my car. Da** those five lug conversions are expensive Thanks alot!
Old Oct 10, 2002 | 03:41 PM
mikedick's Avatar
mikedick
Avenger or Integra??
you may need new axles(not for sure) but I know it shouldnt matter about the lugs, they are on the hubs, not the axles. As long as the axles are a correct fit into your hubs, you may only need axles. Call a part store and ask if they got axles for the current configuration, then ask if they got axles for the type R config. and see if the part # is different.once u have proper axles, see if the axle is a proper fit. hope that helped!
Old Oct 10, 2002 | 04:47 PM
DB7 2.0's Avatar
DB7 2.0
Banned
u dont need the suspension conversion if all youre interested is in the engine swap.
Old Oct 10, 2002 | 04:58 PM
dubcac's Avatar
dubcac
I
you can use the stock axles
Old Oct 11, 2002 | 03:44 PM
ITRraceR's Avatar
ITRraceR
Default .
You can just change the bolts on the hub from stock to i bolts made by APR or something like that, they are suppose to be alot stronger. I know a guy that did that because he swap a prelude motor in to a 92 civic hatch and he still has 4 bolt, total sleeper lol
Old Oct 11, 2002 | 04:14 PM
sir_crx's Avatar
sir_crx
stock axles. Same part #.
Old Oct 14, 2002 | 10:51 AM
reza's Avatar
reza
So factory axles are good to go, huh? Then why do all these people do the five lug conversion? Just to say that they got it and u don't?
Old Oct 14, 2002 | 10:57 AM
BonzoAPD's Avatar
BonzoAPD
pretty much yes. It's a show thing really.
Old Oct 14, 2002 | 11:03 AM
airon's Avatar
airon
AARONNOJIMA.COM
that and also certain rims are made in 5 lug pattern
mostly its an aesthetic thing though
