2.5 - 3.0 Bar Map Sensor
Old May 1, 2007 | 08:13 AM
MC-14's Avatar
MC-14
Tri-man
Default 2.5 - 3.0 Bar Map Sensor
What are the benefits of a 2.5 or 3.0 Bar Map Sensor when you go turbo? How would it be installed? Do I just tap into the stock map sensor? Not sure how all this thing works? Any help or instructions would greatly be appreciated.
Old May 1, 2007 | 08:30 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is so that you can run more boost than the stock MAP sensor can handle which is ~11.2 psi.
You need to wire it into the stock MAP sensor circuit and supply it with a post-throttle body vacuum source. You can then unplug your stock MAP sensor.
Keep in mind that once you do this, you will need a complete retune. All the maps will have to be scaled back accordingly since all the pressure voltages have now changed. That is the biggest reason why my 3.5 bar MAP sensor isn't hooked up yet.
Old May 1, 2007 | 08:38 AM
MC-14's Avatar
MC-14
Tri-man
Thanks dude! What's more preferred, Motorola or GM?
Old May 1, 2007 | 03:29 PM
Provocateur
On permanent hiatus
Most ROM editors are set up to work well with the GM 3 bar.
