Check Engine Light
Old Apr 16, 2007 | 01:45 PM
ryanedward's Avatar
ryanedward
Default Check Engine Light
I have a 99 Acura Integra automatic ! My cel came on and stayed on how can I check it and how can I get a list of what the codes are ! THANKS Ryan
Old Apr 16, 2007 | 01:51 PM
Snoopy's Avatar
Snoopy
been there done that
http://www.c-speedracing.com/faq/06.php
http://www.c-speedracing.com/faq/05.php
Old Apr 16, 2007 | 02:52 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Mine just lit as well, I got a code 14. My IAC (Idle Air Control) valve is bad or unplugged. I just installed a Skunk2 Intake Mani, my question is where is this located?
Thanks
Old Apr 16, 2007 | 03:04 PM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
Ignore the above, I found it and it was loose. Tightened it up, no more problem!
Old Apr 16, 2007 | 06:28 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Would you mind linking people to our FAQ instead?
https://www.honda-acura.net/forums/s...50&postcount=6
https://www.honda-acura.net/forums/s...52&postcount=7
I'm tired of giving CSR and other sites free advertising. h:
Old Apr 16, 2007 | 06:29 PM
lazieb29's Avatar
lazieb29
take it to autozone they will read your codes for you...
Old Apr 16, 2007 | 06:46 PM
Snoopy's Avatar
Snoopy
didnt know they were in there
Old Apr 17, 2007 | 08:19 AM
QuikSilver's Avatar
QuikSilver
Are we Teg yet?
It's way easier and only takes about 2 minutes to jump the plug with a paper clip and get the code yourself. Then look it up, see what that code means. Just as I said above, mine was one, flashed LONG-SHORT-SHORT-SHORT-SHORT which translates to code 14 and it was the IAC valve. Turns out when I switched intakes, I forgot to torque the bolts down. Tightened em', no more problem.
Old Apr 17, 2007 | 05:04 PM
TheOtherDave™
Apathy Kills
So that we stay on topic... just get the code read and report back to us.
Old Apr 17, 2007 | 06:48 PM
TheOtherDave™
Apathy Kills
Stop arguing about how to retrieve the CEL code or both of you will be warned.
You're both crapping the thread with pointless bickering and such behavior will not be tolerated.
