gsr rods.help.......confused
Old Apr 4, 2007 | 01:47 PM
hondamastermind's Avatar
hondamastermind
Default gsr rods.help.......confused
i'm getting ready to build my motor,a 1997 gsr (at my uncles machine shop) and i am confused about the rods i purchased. i know the gsr rods have a p72 casted into them,and no R marking, so i bought what i thought were type r's, as they had an r forged into the beam. however the rod cap has a p72 forged into it...........i thought type r's were p73? anyways the rod bolts have the dimples for a stretch gauge, and the caps are not different (there perfectly round, and have a weird paint number mark covering both rod and cap at the split, they all match correspondingly. my question is does anyone know if there is a type r with a p72 casting number? as i want the strength of the r rod, but am not shure if thats what i ended up with. thanks guys
Old Apr 4, 2007 | 02:41 PM
Snoopy's Avatar
Snoopy
been there done that
did you buy aftermarket rods?
fyi, oem gsr and itr rods are nearly identical
Old Apr 4, 2007 | 02:44 PM
hondamastermind
no, i want to stay oem on this build, aftermarket is always easer, when it comes to part numbers........well most of the time.
Old Apr 4, 2007 | 02:50 PM
hondamastermind
yes i know, the only difference is the weight (due to a stronger lighter steel) and the markings,( ive even seen them have a slightly different color too) the p72 , and the r marking are what have me confused. ive always seen the r and the p73 associated together, never the p72 though. and without a gsr rod to compare the weight to , i thought maby someone else ran across the same thing. thanx
Old Apr 7, 2007 | 12:45 AM
Toy Civic's Avatar
Toy Civic
The geometry is the exact same between both rods. Whether the rods are better and stronger than GSR................that is a good one. But you know what? Eagle rods are awesome and are fairly inexpensive.
Old Apr 7, 2007 | 09:12 AM
if your going to stick with oem rods you should have just upgraded the rod bolts. thats the weakest point of the connecting rods. by going from GSR to type R rods i really dont see any improvement.
Old Apr 9, 2007 | 09:54 PM
hondamastermind
already got arp 2000's for them, as for the eagles, i would love um, however, i already invested my money in the r's and bolts (about 200 bucks) they should be more than strong enough, im thinking i have jdm p72's ,hence the r marking. anyhow thanks for all your positive input,i'm new to the whole forum deal, so its nice to know theirs people willing to lend a hand. thanks steve :cheers:
Old Apr 10, 2007 | 05:27 AM
i guess thats not a bad price. i think my eagles cost me 375...
Old Apr 10, 2007 | 09:51 AM
hondamastermind
its going be my day to day driver, (my 69 big block camero, is killing me on gas) so i am building an import, i have a jrsc for it and am only going to run the 4 inch pulley,so i don't think the boost will be high enough to need eagles...........however in 6 months or so ill probly rip the thing back out and spend some more green, sleeve it, take her out to 84mm and do a full eagle rotating assembly, with wiseco pistons, toped off with a gt35 turbo,and hondata s300. this is my first integra, i've personally owned, im not shure what to expect yet. im gona try to match 514cid big block torque, with high reving horspower!!! and 25 mpg of course :rockon:
