excessive tire wear
Old Mar 6, 2007 | 07:45 PM
gta4life's Avatar
gta4life
Default excessive tire wear
hey how you all doing? im having a slight problem with the tires on my carr i just bought some used wilnter tires for my car like 2 months ago and already the front tires are pretty much bald all around already and i cant explain why as i dont think it is a camber issue, i then had them rotated like a week ago and it looks as if it is starting to have the same problemm, so i guess im wondering what it is that could be causing this fast tire wear, also i have noticed that when i start accelerating the front end is making a kind of whirring sound which only gets louder as i go faster, are these two problems related or seperate? thanks
Old Mar 6, 2007 | 09:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds like you could benefit from an alignment. The toe is probably out of spec causing both the rapid tire wear and the whirring noise.
When was it last aligned and does it do the same thing with a different set of tires on?
Old Mar 7, 2007 | 05:50 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
My thoughts exactly.
Old Mar 7, 2007 | 07:27 AM
fjm1's Avatar
fjm1
G35
winter tires wear fast and are noisy
How many miles you put on the car since installing the used winter tires? How used were they?
If the tires are wearing evenly and the car tracks straight I would not get an alignment
Old Mar 7, 2007 | 08:04 AM
KarrNtegGSR's Avatar
KarrNtegGSR
I agree sounds like a alignment problem.
Old Mar 7, 2007 | 10:25 AM
gta4life's Avatar
gta4life
yahh i could probobly use and alignmentt i havent done one yet since ive had the car, and i have to say i guess the tires arent really winter tires more like all season, would this change anything? and they looked almost brand new when i bought them, i will go for an alignment and hopefully it fixes this problem
Old Mar 10, 2007 | 05:33 PM
nsxtasy's Avatar
nsxtasy
One other possibility is that it could be due to a problem with your suspension - worn/cracked bushings, bent control arm, etc.
Old Mar 12, 2007 | 01:35 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Check under the car first and see if anything is worn out/damaged suspension components. If everything seems fine then get an alignment.
Old Mar 16, 2007 | 07:53 AM
Spec R's Avatar
Spec R
just because your car tracks straight and you think your tires arent wearing funny is NOT an excuse not to get an alignment.
at the very least, get your car on a rack and see where everything is at. if you're like "bah i dont need one" then so be it.
i have lifetime alignment deals on both of my cars and get an alignment every other oil change. my cars track straight as an arrow, have good tire wear but the toe specs always change within those 5k miles
DB Squad
Integra Forum Moderator
Old Mar 16, 2007 | 12:51 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Oh and make sure your tire pressures are where they should be. People always make this mistake of having incorrect tire pressures that cause premature wear.
