gauge cluster not working
i drive a 91 ls and i checked the fuses and checked for loose wires and all that but i cant figure out why my temp, gas, and tach wont work. has anyone else hads this problem ? should i just bite the bullet and take it to a shop? thanks
I actually had the same problem a couple days ago, mine ended up being a bad fuse. Still not sure why it blew but i replaced it and everything is good again. Did you check ALL the fuses, because i know there is a few instrument panel fuses i believe.
