belts
Old Jan 27, 2007 | 01:58 PM
mikeybaby's Avatar
mikeybaby
Default belts
My ac and ps belt were due for a change I figured out how to get my ps belt off but i cant seem to get off my ac belt and I cant find any diy's does any one have any tips that I could use.
Old Jan 27, 2007 | 02:06 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You will need to remove that motor mount to remove the belt. Just unscrew the two bolts holding it to the frame and then the main bolt holding it to the motor.
Old Jan 27, 2007 | 11:23 PM
mikeybaby's Avatar
mikeybaby
ok thanks
Old Jan 30, 2007 | 12:07 PM
mikeybaby's Avatar
mikeybaby
its not the bolt on the bottom is it
Old Jan 30, 2007 | 04:28 PM
Provocateur
On permanent hiatus
Which bolt are you referring to? There should be a large bolt holding the mount to the motor and two smaller bolts holding the mount to the frame. Remove those three and you will be golden.
Old Jan 31, 2007 | 03:36 PM
mikeybaby's Avatar
mikeybaby
alright thanks a bunch i was looking at the bolt that was eunder on the bottom kind of hard to explain lol
