drain plug
hi i have a bit of a problem my drain plug bolt is stripped because it just keeps on turning. So i tryed to drop thet oil pan but i unscrew all of the screws and the right side wont come fully down the one that is under the car any one no why?
I hope this helps but,
1. remove your header
2. There are two black bracers (stiffers schmoo calls them, three bolts each) you need to remove those located to left (reference picture).
4. Then remove the flywheel cover (thin black sheet of metal w/ a few 10mm bolts I believe).
5. screw driver to pray off the oil pan (assuming you remove all the 10mm bolts since after you remove the flywheel cover, you un-cover 4 more 10mm bolts hold the oil pan on.
Here's a picture from my turbo install when i took off the oil pan.
