speedometer
Old Dec 31, 2006 | 11:32 AM
purpleheaz's Avatar
purpleheaz
Default speedometer
hey im new here and ive looked on this site a couple times before, but i was concerned on what to do with my current situation..that is the other day i started my 98 integra ls up and i was driving and i noticed that my speedometer didnt work and the odometer but everything else was fine. i looked around and found to look for the VSS or see if the connection to the cluster was ok, i check the connection that was fine but i dont get why it stopped working out of no where and i was wonderin if someone could help me on findin the VSS or just simply help me. thanks a lot
Old Dec 31, 2006 | 11:46 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The VSS is located on top of the transmission.
You can troubleshoot anything using this.
Old Jan 1, 2007 | 05:01 PM
purpleheaz's Avatar
purpleheaz
thanks for the help..but i dont get why the the speedometer stopped working randomly
Old Jan 2, 2007 | 10:42 AM
FooD2000's Avatar
FooD2000
Still Water
Well when the speedometer stops working, generally it's speedcable (which we don't have since it's electronic), VSS or the gauge cluster itself.
If the rpm / speedometer is both out then i'd try the gauge cluster but in this case, i'm guessing it's the vss.
*edit* here's Vss solde for $30 http://www.homemadeturbo.com/forum/i...?topic=70770.0
