I plan on rebuilding my gsr motor with type r pistons and buddy club cams!!! Is it ok to turbo my motor with this high of compression? whats the max boost i can run!! this is my daily driver so i will need it to be reliable thanks for the help
Typically, N/A and turbo parts do not go well together. If you can see yourself going turbo down the road, you should rebuild the motor with parts meant for a turbo motor. I wouldn't go with anything besides OEM Honda cams for a turbo motor.
so i can turbo my car if i use the type r cam shaft?
The ITR camshaft is a decent choice, but I would be more worried about the bottom end. Leave the camshafts alone if you are set on turbo and save up a bit more for some forged pistons of stock or slightly lower compression ratio.
