gsr tranny
Old Dec 24, 2006 | 04:49 PM
kenny7231's Avatar
kenny7231
Originally Posted by hitman619
here in So.Cal a used gsr transmission runs about the same as Rebuilding one
check around your local transmission shops for prices
be careful of the old "bait and switch"
junk yard wanted 750.00 inculding labor 6 month warranty
Transmisson place wanted 875.00 and included a type R limted slip
plus a 12 month warranty
not bad i think
Old Dec 24, 2006 | 07:34 PM
Black Ack's Avatar
Black Ack
Black Acura Driver
Try replacing the tranny fluid first. A lot of times it will reduce/eliminate grinds simply because you're flushing out any particulates that are floating around in there that could be causing the grinding, and it'll save you a heap of money if it works. I changed mine when it was starting to get notchy to GM Synchromesh and... no more notchiness!!! Honda MTF and Redline are also good alternatives. Good luck.
Old Dec 24, 2006 | 10:52 PM
kenny7231's Avatar
kenny7231
where can i get gm synchromesh from? autozone? is the honda mtf or redline better?
Old Dec 25, 2006 | 07:06 AM
Snoopy's Avatar
Snoopy
been there done that
you can get gm syncromesh from any gm dealership parts department. make sure to get the friction modified version and not the friction modifier.
Old Dec 25, 2006 | 09:56 AM
kenny7231's Avatar
kenny7231
is the honda mtf oil better?
Old Dec 25, 2006 | 05:13 PM
Snoopy's Avatar
Snoopy
since you have a grinding tranny the syncromesh might do you some good
Old Dec 25, 2006 | 06:08 PM
kenny7231's Avatar
kenny7231
how many quarts do i need? thanks
Old Dec 25, 2006 | 06:12 PM
Snoopy's Avatar
Snoopy
i think it's 3-4
Old Dec 25, 2006 | 06:25 PM
kenny7231's Avatar
kenny7231
damn is this stuff expensive?
Snoopy's Avatar
Snoopy
i think it's $10-13/quart. well worth it if it gets rid of the grinds.
