Gas Mileage
Is all your driving stop-n-go or short trips?
My mileage took a hit when I moved down to the Valley because all my trips grew shorter and in many cases, slower. :hs:
However, if you're spending all your time at 55+ mph and getting 21 mpg, that's a different story.
h:
h:
City yes normal freway at 65-70 Nope sounds low...
I get about 20-23 overall city and freway driving also i hit traffic alot of way to work so its stop and go..
dang...i usually get around the same mpg...now im worries...i usually do a mix of stop and go driving and some highway driving considering i live in the country....hmmm...is 21.5mpg really alll that bad?
Things you can do to improve gas milage:
Check spark plugs
Check Alinment
Try to drive 65-70 on freway i read somewhere if you drive even 75 that makes a BIG difference as far as gas milage..
Check tires
Try to drive where you dont do jump starts, (Eats gas like crazy then you do that) Also avoid breaking to hard.
thats pretty much it
I do a mix of both as well and I cruise the freeway at 75-80, but I still get about 26-28 mpg in my LS. 21mpg sounds kinda low for some highway driving.
